[GRASS-user] Interpolation with faultlines?
Maciej Sieczka
tutey at o2.pl
Thu Feb 21 14:42:50 EST 2008
Moritz Lennert pisze:
> On 13/02/08 18:40, G. Allegri wrote:
>> It's the same question I was going to ask. It would be an important
>> advance in Grass, as I'm obliged to use commercial sw to do it (Esri)
>> both to interpolate with barriers and to do 3D TINs with constraints.
> The answer was (and as far as I know still is) to either run v.surf.rst
> several times, once for each part within fault lines (using mask) or to
> use r.surf.nnbathy (AddOns).
r.surf.nnbathy does not support fault lines either.
FWIW, there is surfit [1] (FOSS). It supports fault lines AIUI - linear
features which don't have a value assigned, but only depict a curve at
which the interpolation should break. They call break/fault lines
"inequalities". I still haven't used surfit, but from examples [2] it
seems interesting.
[1]http://surfit.sourceforge.net
[2]http://surfit.sourceforge.net/surfit/examples.html
Maciek
