[GRASS-user] circular neighborhoods?
Patton, Eric
epatton at nrcan.gc.ca
Thu Feb 21 14:15:37 EST 2008
>So in a 3x3 example, neighborhoodSize=3, neighborhoodDistance=1, and your
>first diagram has "o"s where the mask is true. The corners of the square
>wouldn't be in the mask (as in Eric's 3x3), because those points would have
>the left hand side of the inequality equal to 2, making the mask false.
>I haven't actually *tried* the code, but that is what the block of code in
>gather.c for circular neighborhoods says it should be doing.
Thanks for the info - I wasn't even aware that r.neighbors could do that, as
I've always used the square windows for my work.
If I get a chance to test it out, I'll report back on what happening.
~ Eric.
