[GRASS-user] circular neighborhoods?
Carlos "Guâno" Grohmann
carlos.grohmann at gmail.com
Thu Feb 21 15:09:31 EST 2008
Thanks for the quick answer Tom.
Carlos
On Thu, Feb 21, 2008 at 3:52 PM, Tom Russo <russo at bogodyn.org> wrote:
> On Thu, Feb 21, 2008 at 03:11:43PM -0300, we recorded a bogon-computron collision of the <carlos.grohmann at gmail.com> flavor, containing:
> > Yes, Eric, that is what it does for a _square_ neighborhood. I am a
> > little confuse about the actual shape of the _circular_ neighborhood.
> > using your examples:
> > will a 3x3 circular neighborhood look like this:?
> > ---o---
> > o-X-o
> > ---o---
> > and a 5x5?
> > ---o-o-o---
> > o-o-o-o-o
> > o-o-X-o-o
> > o-o-o-o-o
> > ---o-o-o---
> > maybe now my question is more clear...
> Piping in here after a quick glance at the source code...
> When the "-c" option to r.neighbors is selected, a neighborhood mask of booleans
> is created by this loop (in pseudocode):
> neighborhoodDistance=neighborhoodSize/2 (in integer math)
> for (i=0; i<neigborhoodSize; i++)
> for (j=0; j<neighborhoodSize; j++)
> mask[i][k]= ( (i-neighborhoodDistance)^2 + (j-neighborhoodDistance)^2 <= (neighborhoodDistance)^2
> So in a 3x3 example, neighborhoodSize=3, neighborhoodDistance=1, and your
> first diagram has "o"s where the mask is true. The corners of the square
> wouldn't be in the mask (as in Eric's 3x3), because those points would have
> the left hand side of the inequality equal to 2, making the mask false.
> I haven't actually *tried* the code, but that is what the block of code in
> gather.c for circular neighborhoods says it should be doing.
> > > >I was thinking about the circular neighborhoods that r.neighbors use.
> > > >How exactly are they shaped? I mean, in a 3x3 window, does the
> > > >circular one looks like a cross? and then it start to look more like a
> > > >circle as the size increases?
> > > As far as I understand it,
> > > A 3x3 window would look like this:
> > > o-o-o
> > > o-X-o
> > > o-o-o
> > > Where the 'X' is the current cell being processed. Similarly, a 5X5 window
> > > o-o-o-o-o
> > > o-o-o-o-o
> > > o-o-X-o-o
> > > o-o-o-o-o
> > > o-o-o-o-o
> > > r.neighbors will perform calculations on all the cells I've marked 'o' and and
> > > assign the output value to 'X', according to whatever method has been chosen
> > > (i.e., average, median, min, max, etc.).
> > > ~ Eric.
> > Carlos Henrique Grohmann - Guano
> > Geologist M.Sc - Doctorate Student at IGc-USP - Brazil
> > Linux User #89721 - carlos dot grohmann at gmail dot com
> > _________________
> > "Good morning, doctors. I have taken the liberty of removing Windows
> > 95 from my hard drive."
> > --The winning entry in a "What were HAL's first words" contest judged
> > by 2001: A SPACE ODYSSEY creator Arthur C. Clarke
> > Can't stop the signal.
> > grass-user mailing list
> > grass-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/grass-user
> Tom Russo KM5VY SAR502 DM64ux http://www.swcp.com/~russo/
> Tijeras, NM QRPL#1592 K2#398 SOC#236 AHTB#1 http://kevan.org/brain.cgi?DDTNM
> "And, isn't sanity really just a one-trick pony anyway? I mean all you get is
> one trick, rational thinking, but when you're good and crazy, oooh, oooh,
> oooh, the sky is the limit!" --- The Tick
_________________
