[GRASS-user] automating map production in Grass
David Finlayson
dfinlayson at usgs.gov
Thu Feb 21 20:37:04 EST 2008
If you find ps.map too limiting, you can also use GMT for map
production. There are a few add-on scripts available for transferring
data back and forth between GMT and GRASS.
David
On Thu, Feb 21, 2008 at 6:21 PM, Glynn Clements
<glynn at gclements.plus.com> wrote:
> Alysson Whitlam wrote:
> > I am just beginning to work with Grass, although I am fairly experienced
> > with ArcGIS, including scripting for map production and geoprocessing
> > (Python and VBA). Basically, I am looking to automate map production in
> > Grass, using a script (Python or Perl preferably?). (I have to output
> > several hundred maps, based on sections of a polygon layer). Since I am just
> > beginning to use Grass, I am wondering if anyone could please give me an
> > idea if this type of task can be accomplished in Grass.
> Others have already suggested ps.map. You can also create PostScript
> output using d.* commands with the PS driver, which may be more
> flexible. However, a few commands either don't work well with the PS
> driver, or require specific options. In particular, d.vect requires
> you to use render= option to select something other than "g".
> Glynn Clements <glynn at gclements.plus.com>
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
David Finlayson, Ph.D.
Operational Geologist
U.S. Geological Survey
Pacific Science Center
400 Natural Bridges Drive
Santa Cruz, CA 95060, USA
Tel: 831-427-4757, Fax: 831-427-4748, E-mail: dfinlayson at usgs.gov
