[GRASS-user] Re: Does Grass Support The following ???
Kunal Malik kunal.malik81 at gmail.com
Fri Feb 22 02:22:42 EST 2008
ok,,,
Jachym .
would u please elaborate on this point.
Thnks
On 2/22/08, Jachym Cepicky <jachym.cepicky at gmail.com> wrote:
> maybe you do not need grass at all.
> try to have a look at mapserver (for the server part) and openlayers
> (for the client part)
> http://mapserver.gis.umn.edu
> http://openlayers.org
> jachym
> Kunal Malik píše v Pá 22. 02. 2008 v 12:08 +0530:
> > Hi!
> > 1)...
> > I want to create different layers..on selection user must be able to
> > display layers by checkbox...once  user select the checkbox..he is
> > able to see the different layers like roads,rails,river..when he
> > unselect the checkbox..the layers should be removed.,..
> > 2..)
> > stichining of Maps means tiling of Maps..user have 50mb of raster maps
> > avaliable in 4 files say..
> > stitching means to get the complete image by placing them together,,,
> > 3),,
> > I want to start with the development ...so i want to make a small test
> > program in C/C++..so that i could display the raster/vector image
> > through code now..do u have such code snippet ..also i want to know
> > wat r the libraires required to start the development,,...
> >         Hi,
> >         Kunal Malik píše v Pá 22. 02. 2008 v 10:33 +0530:
> >         > HI!!
> >         > I have displayed my raster & vector Images.
> >         > NOw i want to start with the development using the grass
> >         tools.
> >         > How could i use Grass in conjuction with the Map Server.????
> >         > I want to develop the client-server architecture,
> >         Basically, you can setup MapServer, so it can access data
> >         (both, raster
> >         and vector) and serv them to clients. See
> >         http://mapserver.gis.umn.edu/docs/howto/raster_data and
> >         http://grass.gdf-hannover.de/wiki/GRASS_and_MapServer
> >         for more detail.
> >         > I want the map server should run on Server &  n number of
> >         Client  can
> >         > request them ..
> >         > Since I want to start with the developemt ,could u recommend
> >         any book
> >         > for this..I am not able to find any books,,the books
> >         avaliable on the
> >         > internet have the limited preview and they are not complete.
> >         http://spatialguru.com/book/sherman_davis
> http://www.amazon.com/dp/0596008651?tag=webmappingi06-20&amp;camp=14573&amp;creative=327641&amp;linkCode=as1&amp;creativeASIN=0596008651&amp;adid=0WERXH1HX6ND63WF84WG&amp
> >         http://www.grassbook.org/
> >         > could u please tell the following tasks could be
> >         accomplished in
> >         > grass ??
> >         > 1.Import & Export  Map(TF,GeoTif,IMG,DTED,SHP,BMP,DVD,DGN).
> >         v.in.ogr / r.in.gdal
> >         v.out.ogr / r.out.gdal
> >         see also http://www.gdal.org/formats_list.html and
> >         http://www.gdal.org/ogr/ogr_formats.html
> >         for details
> >         > 2.)Registration of Map-->Datum Used is wgs84.
> >         r.proj / gdal_translate
> >         > 3)Raster to Vector Conversion & Vice Versa
> >         r.to.vect / v.to.rast
> >         > 4) Create Layer
> >         ?? v.digit, v.edit, r.mapcalc, r.*, v.*
> >         > 5)Grouping & Separation of Layers.
> >         i.group - but that is probably not, what you are looking for
> >         > 6) Hide/Unhide Layers.
> >         do not understand. the layer is displayed, when you request it
> >         and it is
> >         not displayed, when you request it
> >         > 7)Edit/Delete layers,
> >         g.remove
> >         > 8)Stiching of Map.
> >         do not understand
> >         jachym
> >         > Please help me to resolve these queries,
> >         > Thanks in Advance.
> >         > Thanks & Regards
> >         > Kunal Malik
> >         > 09871147561
> >         Jachym Cepicky
> >         e-mail: jachym.cepicky gmail com
> >         URL: http://les-ejk.cz
> >         GPG: http://www.les-ejk.cz/pgp/jachym_cepicky-gpg.pub
> > Thanks & Regards
> > Kunal Malik
> > 09871147561
> Jachym Cepicky
Thanks & Regards
Kunal Malik
09871147561
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20080222/ce0c200e/attachment-0001.html
