[GRASS-user] Re: Does Grass Support The following ???
Jachym Cepicky
jachym.cepicky at gmail.com
Fri Feb 22 01:43:35 EST 2008
maybe you do not need grass at all.
try to have a look at mapserver (for the server part) and openlayers
(for the client part)
http://mapserver.gis.umn.edu
http://openlayers.org
jachym
Kunal Malik píše v Pá 22. 02. 2008 v 12:08 +0530:
> Hi!
> 1)...
> I want to create different layers..on selection user must be able to
> display layers by checkbox...once user select the checkbox..he is
> able to see the different layers like roads,rails,river..when he
> unselect the checkbox..the layers should be removed.,..
> 2..)
> stichining of Maps means tiling of Maps..user have 50mb of raster maps
> avaliable in 4 files say..
> stitching means to get the complete image by placing them together,,,
> 3),,
> I want to start with the development ...so i want to make a small test
> program in C/C++..so that i could display the raster/vector image
> through code now..do u have such code snippet ..also i want to know
> wat r the libraires required to start the development,,...
> On 2/22/08, Jachym Cepicky <jachym.cepicky at gmail.com> wrote:
> Hi,
> Kunal Malik píše v Pá 22. 02. 2008 v 10:33 +0530:
> > HI!!
> > I have displayed my raster & vector Images.
> > NOw i want to start with the development using the grass
> tools.
> > How could i use Grass in conjuction with the Map Server.????
> > I want to develop the client-server architecture,
> Basically, you can setup MapServer, so it can access data
> (both, raster
> and vector) and serv them to clients. See
> http://mapserver.gis.umn.edu/docs/howto/raster_data and
> http://grass.gdf-hannover.de/wiki/GRASS_and_MapServer
> for more detail.
> > I want the map server should run on Server & n number of
> Client can
> > request them ..
> > Since I want to start with the developemt ,could u recommend
> any book
> > for this..I am not able to find any books,,the books
> avaliable on the
> > internet have the limited preview and they are not complete.
> http://spatialguru.com/book/sherman_davis
> http://www.amazon.com/dp/0596008651?tag=webmappingi06-20&camp=14573&creative=327641&linkCode=as1&creativeASIN=0596008651&adid=0WERXH1HX6ND63WF84WG&
> http://www.grassbook.org/
> > could u please tell the following tasks could be
> accomplished in
> > grass ??
> > 1.Import & Export Map(TF,GeoTif,IMG,DTED,SHP,BMP,DVD,DGN).
> v.in.ogr / r.in.gdal
> v.out.ogr / r.out.gdal
> see also http://www.gdal.org/formats_list.html and
> http://www.gdal.org/ogr/ogr_formats.html
> for details
> > 2.)Registration of Map-->Datum Used is wgs84.
> r.proj / gdal_translate
> > 3)Raster to Vector Conversion & Vice Versa
> r.to.vect / v.to.rast
> > 4) Create Layer
> ?? v.digit, v.edit, r.mapcalc, r.*, v.*
> > 5)Grouping & Separation of Layers.
> i.group - but that is probably not, what you are looking for
> > 6) Hide/Unhide Layers.
> do not understand. the layer is displayed, when you request it
> and it is
> not displayed, when you request it
> > 7)Edit/Delete layers,
> g.remove
> > 8)Stiching of Map.
> do not understand
> jachym
> > Please help me to resolve these queries,
> > Thanks in Advance.
> > Thanks & Regards
> > Kunal Malik
> > 09871147561
> Jachym Cepicky
> e-mail: jachym.cepicky gmail com
> URL: http://les-ejk.cz
> GPG: http://www.les-ejk.cz/pgp/jachym_cepicky-gpg.pub
> Thanks & Regards
> Kunal Malik
> 09871147561
Jachym Cepicky
Name: not available
Desc: Toto je =?UTF-8?Q?digit=C3=A1ln=C4=9B?=
=?ISO-8859-1?Q?_podepsan=E1?= =?UTF-8?Q?_=C4=8D=C3=A1st?=
=?ISO-8859-1?Q?_zpr=E1vy?=
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20080222/2211ad53/attachment.bin
