[GRASS-user] Re: Does Grass Support The following ???
Kunal Malik kunal.malik81 at gmail.com
Fri Feb 22 01:38:49 EST 2008
Hi!
1)...
I want to create different layers..on selection user must be able to display
layers by checkbox...once  user select the checkbox..he is able to see the
different layers like roads,rails,river..when he unselect the checkbox..the
layers should be removed.,..
2..)
stichining of Maps means tiling of Maps..user have 50mb of raster maps
avaliable in 4 files say..
stitching means to get the complete image by placing them together,,,
3),,
I want to start with the development ...so i want to make a small test
program in C/C++..so that i could display the raster/vector image through
code now..do u have such code snippet ..also i want to know wat r the
libraires required to start the development,,...
On 2/22/08, Jachym Cepicky <jachym.cepicky at gmail.com> wrote:
> Hi,
> Kunal Malik píše v Pá 22. 02. 2008 v 10:33 +0530:
> > HI!!
> > I have displayed my raster & vector Images.
> > NOw i want to start with the development using the grass tools.
> > How could i use Grass in conjuction with the Map Server.????
> > I want to develop the client-server architecture,
> Basically, you can setup MapServer, so it can access data (both, raster
> and vector) and serv them to clients. See
> http://mapserver.gis.umn.edu/docs/howto/raster_data and
> http://grass.gdf-hannover.de/wiki/GRASS_and_MapServer
> for more detail.
> > I want the map server should run on Server &  n number of Client  can
> > request them ..
> > Since I want to start with the developemt ,could u recommend any book
> > for this..I am not able to find any books,,the books avaliable on the
> > internet have the limited preview and they are not complete.
> http://spatialguru.com/book/sherman_davis
> http://www.amazon.com/dp/0596008651?tag=webmappingi06-20&camp=14573&creative=327641&linkCode=as1&creativeASIN=0596008651&adid=0WERXH1HX6ND63WF84WG&
> http://www.grassbook.org/
> > could u please tell the following tasks could be accomplished in
> > grass ??
> > 1.Import & Export  Map(TF,GeoTif,IMG,DTED,SHP,BMP,DVD,DGN).
> v.in.ogr / r.in.gdal
> v.out.ogr / r.out.gdal
> see also http://www.gdal.org/formats_list.html and
> http://www.gdal.org/ogr/ogr_formats.html
> for details
> > 2.)Registration of Map-->Datum Used is wgs84.
> r.proj / gdal_translate
> > 3)Raster to Vector Conversion & Vice Versa
> r.to.vect / v.to.rast
> > 4) Create Layer
> ?? v.digit, v.edit, r.mapcalc, r.*, v.*
> > 5)Grouping & Separation of Layers.
> i.group - but that is probably not, what you are looking for
> > 6) Hide/Unhide Layers.
> do not understand. the layer is displayed, when you request it and it is
> not displayed, when you request it
> > 7)Edit/Delete layers,
> g.remove
> > 8)Stiching of Map.
> do not understand
> jachym
> > Please help me to resolve these queries,
> > Thanks in Advance.
> > Thanks & Regards
> > Kunal Malik
> > 09871147561
> Jachym Cepicky
> e-mail: jachym.cepicky gmail com
> URL: http://les-ejk.cz
> GPG: http://www.les-ejk.cz/pgp/jachym_cepicky-gpg.pub
Thanks & Regards
Kunal Malik
09871147561
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20080222/571f3730/attachment.html
