[GRASS-user] d.rast.edit does not save edited cells (?)
Nikos Alexandris
nikos.alexandris at felis.uni-freiburg.de
Fri Feb 22 13:32:18 EST 2008
I just now realised the use of the "right mouse button". But I am not
able to figure out how the "middle" button works. How does it work? I
take back my words for the "magic" key if this "highlight" function is
working ;-)
Cheers,
Nikos
On Fri, 2008-02-22 at 04:41 -0800, Hamish wrote:
> Nikos Alexandris wrote:
> > And why not having a magic "key" with which one can "fly" over pixels
> > with the mouse pointer and assign new values instead of "countless
> > clicks".
> FWIW I find the old xmon & terminal based d.rast.edit's 3 button
> click-workflow to be incredibly well thought out and implemented. It
> has a nice compromise of speed, simplicity, and caution which has a
> natural feel to it. The need for an undo button is not as great if you
> have a same-button confirmation click. Having to do a pseudo double
> click doesn't slow you down much, and the mid-click higlight gives your
> brain a chance to reconsider/redo.
> The annoying thing with the old version is that you can't add a value
> outside of that map's range, but that relic has nothing to do with the
> workflow design.
> Hamish
> ____________________________________________________________________________________
> Never miss a thing. Make Yahoo your home page.
> http://www.yahoo.com/r/hs
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
Nikos Alexandris
Department of Remote Sensing & Landscape Information Systems
Faculty of Forestry & Environmental Sciences, Albert-Ludwigs-University Freiburg
Tel. +49 (0) 761 203 3697 / Fax. +49 (0) 761 203 3701 / Skype: Nikos.Alexandris
Address: Tennenbacher str. 4, D-79106 Freiburg i. Br., Germany
Name: not available
Desc: This is a digitally signed message part
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20080222/37d585e3/attachment.bin
