[GRASS-user] How GRASS saves raster cell values?
Glynn Clements
glynn at gclements.plus.com
Fri Feb 22 21:13:56 EST 2008
christian Brandt wrote:
> I would like to rasterize a vector map with building data (including
> attribute data) but I am not sure how several buildings (e.g. the
> building areas) are acknowledged within one cell (value). For example,
> there is a raster resolution of 100x100 m, so I presumably get about
> 8-10 buildings within one raster cell.
> Now the question is how does GRASS calculate the cell values based on
> the building theme's attribute <area>. Does it take the mean value?
> And does GRASS recognize if one building extends over more than one
> cell (and how?).
There isn't much point trying to rasterise features that small.
First, the code to rasterise vectors is littered with fudges which
will move vertices by up to one cell.
Also, if multiple polygons cover a particular cell, the cell's value
will be determined by the last polygon rendered.
