[GRASS-user] Re: wxpython gui: error while loding avevry first
layer
G. Allegri
giohappy at gmail.com
Mon Feb 25 06:14:09 EST 2008
Using wx.LogNull() has solved the problem.
I've added it both in wxgui.py and menuform.py, gust before
app.MainLoop() in the main routine.
The GUI appears to load faster too...
Giovanni
2008/2/25, Martin Landa <landa.martin at gmail.com>:
> Ciao,
> can you try to add
> wx.LogNull()
> instance to wxgui.py (launch d.vect/d.rast from GUI) or menuform.py
> (launch for CLI)?
> See
> http://aspn.activestate.com/ASPN/Mail/Message/wxPython-users/3609948
> Regards, Martin
> 2008/2/25, G. Allegri <giohappy at gmail.com>:
> > As Martin Landa has suggested me, it's a problem related to wxpython
> > and KDE, not Grass.
> > Giovanni
> > > Hi,
> > > I'm playing with the new gui. I've tried it yesterday for the first
> > > time: it rocks!
> > > There are some warning and little errors the come raised with some
> > > tasks, but everything seems to work fine.
> > > The first error I've experimented is:
> > > 23:57:44: Can not enumerate files in directory
> > > '/home/giova/.kde/share/mimelnk/text' (error 13: Permesso negato)
> > > 23:57:46: Can not enumerate files in directory
> > > '/home/giova/.local/share/applications' (error 13: Permesso negato)
> > > It happens when I launch d.vect or d.rast the very first time. I click
> > > ok and the d.vect (d.rast) window opens correctly. The subsequent
> > > times I do it, it doesn't happen...
> > > Great work!
> > > Thanks,
> > > Giovanni
> > grass-user mailing list
> > grass-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/grass-user
> Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
