[GRASS-user] Re: wxpython gui: error while loding avevry first layer
G. Allegri giohappy at gmail.com
Mon Feb 25 06:23:02 EST 2008
To be exact, I0ve added q=wx.LogNull()
 - before app.MainLoop inside wxgui.py
 - before GrassGUIApp( task ).MainLoop() inside menuform.py
2008/2/25, G. Allegri <giohappy at gmail.com>:
> Using wx.LogNull() has solved the problem.
>  I've added it both in wxgui.py and menuform.py, gust before
>  app.MainLoop() in the main routine.
>  The GUI appears to load faster too...
>  Giovanni
>  2008/2/25, Martin Landa <landa.martin at gmail.com>:
> > Ciao,
>  >  can you try to add
>  >  wx.LogNull()
>  >  instance to wxgui.py (launch d.vect/d.rast from GUI) or menuform.py
>  >  (launch for CLI)?
>  >  See
>  >  http://aspn.activestate.com/ASPN/Mail/Message/wxPython-users/3609948
>  >  Regards, Martin
>  >  > As Martin Landa has suggested me, it's a problem related to wxpython
>  >  >  and KDE, not Grass.
>  >  >  Giovanni
>  >  > > Hi,
>  >  >  >  I'm playing with the new gui. I've tried it yesterday for the first
>  >  >  >  time: it rocks!
>  >  >  >  There are some warning and little errors the come raised with some
>  >  >  >  tasks, but everything seems to work fine.
>  >  >  >  The first error I've experimented is:
>  >  >  >  23:57:44: Can not enumerate files in directory
>  >  >  >  '/home/giova/.kde/share/mimelnk/text' (error 13: Permesso negato)
>  >  >  >  23:57:46: Can not enumerate files in directory
>  >  >  >  '/home/giova/.local/share/applications' (error 13: Permesso negato)
>  >  >  >  It happens when I launch d.vect or d.rast the very first time. I click
>  >  >  >  ok and the d.vect (d.rast) window opens correctly. The subsequent
>  >  >  >  times I do it, it doesn't happen...
>  >  >  >  Great work!
>  >  >  >  Thanks,
>  >  >  >  Giovanni
>  > >  _______________________________________________
>  >  >  grass-user mailing list
>  >  >  grass-user at lists.osgeo.org
>  >  >  http://lists.osgeo.org/mailman/listinfo/grass-user
>  >  Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
