[GRASS-user] wxpython gui: d.vect.thematic raises error
G. Allegri
giohappy at gmail.com
Mon Feb 25 18:45:19 EST 2008
Sorry Michael. This is the problem: the error raises when I add a
thematic layer in the GUI layer manager... No command line.
2008/2/26, Michael Barton <michael.barton at asu.edu>:
> On Feb 25, 2008, at 9:42 AM, G. Allegri wrote:
> SECOND ERROR: d.vect.thematic
> I create a thematic vector map (from the gui). It's a point layer. I
> ask to use graduated_points on a double type attribute.
> Execution failed: 'd.vect.thematic map=topsoil_completo at tesi
> type=point column=Ece themetype=graduated_points themecalc=interval
> size=9 maxsize=25 nint=10 colorscheme=blue-red --q'
> GRASS_INFO_ERROR(16631,1): *** You must open a display monitor ***
> The same error raises if I launch it from commandline both in wxgrass and
> tcltk.
> Again, I loose control on the GUI and got to kill it.
> In Grass tcltk this command works correctly:
> Sorry I missed your reply. It was trapped by my spam filter.
> This works exactly as it should, since you are not running it in the gui,
> but from the command line. You have to have a window to display the thematic
> map IN.
> If you add a thematic layer in the GUI layer manager, it will take care of
> this chore.
> But if you want to do it the old fashioned way from the command line, you
> need to specify a display of some kind. The default is an x monitor, but you
> can also display from a PNG file. You have to launch these using d.mon.
> Michael
