[GRASS-user] r.in.wms bug
Richard Chirgwin
rchirgwin at ozemail.com.au
Tue Feb 26 00:56:59 EST 2008
Hamish,
- Grass Version: Grass 6.3RC4 (William K's build)
- MAC OSX Leopard
- Using CURL
- I used the r.in.wms interface, which generated this command line:
r.in.wms output=test mapserver=<private> layers=psma:all srs=EPSG:4326
format=png wmsquery=version=1.1.1 maxcols=1024 maxrows=1024
'wgetoptions=-c -t 5 -nv' 'curloptions=-C - --retry 5 -s -S'
method=nearest v=1 --overwrite
The wget options are pre-completed by the r.in.wms UI - should I delete
these?
Richard
Richard Chirgwin wrote:
> I'm having r.in.wms failing with an error
> <path to script>wms.download line 118: eval: -n: invalid option
> <path to script>r.in.wms: line 436: eval: -n: invalid option
can you rerun with:
GRASS> g.gisenv set="DEBUG=1"
(set back to 0 to turn off debug messages)
What version of GRASS?
What platform? mac?
Is wget installed or are you using curl?
What command line options were used?
Hamish
____________________________________________________________________________________
Never miss a thing. Make Yahoo your home page.
http://www.yahoo.com/r/hs
