[GRASS-user] r.in.wms bug
rchirgwin at ozemail.com.au
Tue Feb 26 04:47:55 EST 2008
Hamish,
Hamish wrote:
> Richard Chirgwin wrote:
>> - Grass Version: Grass 6.3RC4 (William K's build)
>> - MAC OSX Leopard
>> - Using CURL
>> - I used the r.in.wms interface, which generated this command line:
>> r.in.wms output=test mapserver=<private> layers=psma:all
>> srs=EPSG:4326
>> format=png wmsquery=version=1.1.1 maxcols=1024 maxrows=1024
>> 'wgetoptions=-c -t 5 -nv' 'curloptions=-C - --retry 5 -s -S'
>> method=nearest v=1 --overwrite
>> The wget options are pre-completed by the r.in.wms UI - should I
>> delete these?
> If you like, but they should be ignored if using Curl.
> Does the script work if you install wget?
Can't use wget, the remote server uses Curl. I will fetch the debugs for
you tomorrow.
RC
> Hamish wrote:
>> can you rerun with:
>> GRASS> g.gisenv set="DEBUG=1"
>> (set back to 0 to turn off debug messages)
> To help more I really need to see that debug output. There is a debug
> message in wms.download on the line before the one that triggers your
> error which echos the attempted eval command. ("g.message -d")
> Hamish
> ____________________________________________________________________________________
> Looking for last minute shopping deals?
> Find them fast with Yahoo! Search. http://tools.search.yahoo.com/newsearch/category.php?category=shopping
