[GRASS-user] postgresql driver
Vassily Poddubny basil at ecko.uran.ru
Wed Feb 27 00:10:19 EST 2008
Hi, Jachym!
Thanks!
Jachym Cepicky пишет:
> hi,
> Vassily Poddubny píše v Út 26. 02. 2008 v 20:18 +0500:
>> Hi!
>> I have postgresql table with point data type column "mypointloc". When i
>> have tried to create vectors (points) object in GRASS 6.2.2
>> v.in.db driver=pg database="localhost,dbname=aeronet" table=mytable
>> x=mypointloc[0] y=mypointloc[1] key=myid output=mynewtable
>> I have got message " WARNING: pg driver: column 'mypointloc', type 600
>> is not supported"!
>> Result table "mynewtable" have not x and y columns.
> afaik you have to specify two new collumns of types (float or double),
> for x and y coordinates.
> grass does not support "point" column type used in potgresql
Does you mean - it is better do not use postgresql tables with point
type? It is strange for me!
>> How I have create vectors(points) objects from postgresql table?
>> Is it possible to create new vectors(points) without creation new
>> attribute table?
> yes, v.in.ascii should do the job
OK! I think it is lucky thought. I will try to create ascii file from
postgresql table and then I will use v.in.ascii.
Thank you!
Basil
