[GRASS-user] postgresql driver
Jachym Cepicky jachym.cepicky at gmail.com
Wed Feb 27 01:04:00 EST 2008
Jachym Cepicky píše v Út 26. 02. 2008 v 16:17 +0100:
> hi,
> afaik you have to specify two new collumns of types (float or double),
> for x and y coordinates.
> grass does not support "point" column type used in potgresql
no, it does not (afaik) support any "point" type in any database. even
postgis implements point type on it's own. you can also store the data
in postgis and import them to grass via v.in.ogr
adding support for the "point" type for postgresql should not be that
hard...
 you can also use `"SELECT point FROM your_table"|v.in.ascii out=points`
approach
jachym
Jachym Cepicky
e-mail: jachym.cepicky gmail com
URL: http://les-ejk.cz
GPG: http://www.les-ejk.cz/pgp/jachym_cepicky-gpg.pub
Name: not available
Desc: Toto je =?UTF-8?Q?digit=C3=A1ln=C4=9B?=
	=?ISO-8859-1?Q?_podepsan=E1?= =?UTF-8?Q?_=C4=8D=C3=A1st?=
	=?ISO-8859-1?Q?_zpr=E1vy?=
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20080227/49f725e3/attachment.bin
