[GRASS-user] v.generalize for polygons?
Hamish
hamish_b at yahoo.com
Wed Feb 27 23:16:25 EST 2008
Hamish:
> > I have a high-res vector area map of regional districts which I
> > wish to generalize. I am having trouble with finding the correct
> > method in v.generalize to use. Currently every thing I try tends
> > to break the area topology and leave only a portion of the now-
> > open boundary.
I have now tried with a related vector, linked below, and it worked
(very!) nicely for that. But it fails with a derivative vector map.
v.digit shows no problems with topography.
Wolf:
> What methods did you try?
many of them.. mainly douglas with a number of threshold values.
> What exact commands have you tried that fail?
at the simplest: v.generalize in= out=
but some areas are missing.
> Can you share the problematic map? (you can email it to me directly)
sure,
starting with:
http://www.stats.govt.nz/statistics-by-area/regional-statistics/geography-mapping/download-digital-boundaries.htm
-- Census based NZMG 2006 (37mb shapefile .zip)
I am looking at regional boundaries (RC) from REGC06_LV2.shp
this map generalizes nicely, but it includes the 12 nautical mile
territorial buffer around the coastline. When I overlay that map with a
detailed coastline is when I see the problem.
I'll send a sample of the v.overlay output off-list.
> v.generalize does preserve nodes, and as long as the input map is
> topologically correct so should the output map be.
ok. (confirmed, it does a very nice job simplifying the above
shapefile)
> Perhaps your threshold is way off?
Possible, as I am just learning. But I did try a number of ranges and
slowly increase. All would be ok for slight generalization then big
breakage.
e.g. it has a big jump between thresh=0.4865 and 0.487
Good:
v.generalize in=rc_merge_coast3 out=rc_gen thresh=0.4865 --o
Number of vertices was reduced from 569815 to 521969 [91%]
Bad:
v.generalize in=rc_merge_coast3 out=rc_gen thresh=0.487 --o
Number of vertices was reduced from 569815 to 336380 [59%]
Daniel:
> However, there is a flag(-r?) which prevents the module from removing
> them.
Flags:
-c Copy attributes
-r Remove lines and areas smaller than threshold
thanks,
Hamish
____________________________________________________________________________________
Looking for last minute shopping deals?
Find them fast with Yahoo! Search. http://tools.search.yahoo.com/newsearch/category.php?category=shopping
