[GRASS-user] Not Able to Run Sample grass data??
mohannbr
mohan_483 at rediffmail.com
Thu Feb 28 03:51:35 EST 2008
Kunal Malik wrote:
> Hi!!
> 1.)I have downloaded grass-6-2.3. and then i add r.example into raster
> dir.
> make neccasy change inn the make file .
> 2)when i run make in raster/ dir ..error comes permanent
> mapset:permission
> denied
> as suggested by jachym i tried to download the source ..but it require
> subversion...so i went for grass-6.2.3..am i wrong here??
> 3) I configure ,make,make install the grass-6.2.3/ dir
> 4) run grass62
> please tell me how could i run my own sample file ..
> after i run grass how it's effect could be seen ...
> r.example is taken from
> http://trac.osgeo.org/grass/browser/grass/trunk/doc/raster/r.example
> Thanks & Regards
> Kunal Malik
> 09871147561
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
I think u have to create new mapset. u'll find an option to do that in the
GRASS startup screen. u can access data in PERMANENT from this mapset
View this message in context: http://www.nabble.com/Not-Able-to-Run-Sample-grass-data---tp15712474p15732132.html
Sent from the Grass - Users mailing list archive at Nabble.com.
