[GRASS-user] Re: [GRASS-dev] r.out.gdal Gtiff output does not
preserve color tables
Dylan Beaudette
dylan.beaudette at gmail.com
Fri Feb 29 13:44:54 EST 2008
On Thursday 28 February 2008, Hamish wrote:
> Hamish:
> > > did you try adding INTERLEAVE=PIXEL and *not* using LZW
> > > compression for createopt=?
> Dylan:
> > Yep-- I have tried both of those options. I either get a file which
> > will not open (mysterious ESRI error),
> I decided (out of complete frustration) never to use Arc again before I
> started much with GRASS, so I can't comment on that. For exporting
> stuff for colleagues I usually go with r.out.arc and don't get many
> complaints.
Tell me about it. The mysterious crashes and licensing headache were enough to
convert me to a completely FOSS GIS toolset.
> > or the file's data range is reported as some huge negative number
> > <--> to some huge positive number, something like 3x10^25 . I will
> > check on the exact value and report back.
The reported range is: (1.17549e-038,3.40282e+038). I have updated my notes
[1] accordingly.
> This will be the nodata value? Or wrong data type? (float read as int)
I think that this is the nodata value bug which has been hinted at before that
is ultimately to blame.
Dylan
1. http://casoilresource.lawr.ucdavis.edu/drupal/node/337
Dylan Beaudette
Soil Resource Laboratory
University of California at Davis
530.754.7341
