[GRASS-user] gdal 1.5 and WMS ressource --- PREVIOUSLY:How to best access hundreds of orthophotos -- mapserver as WMS server?
Moritz Lennert mlennert at club.worldonline.be
Thu Jan 3 09:48:15 EST 2008
On 03/01/08 14:06, Rainer M Krug wrote:
> Moritz Lennert wrote:
>> On 02/01/08 21:37, sebastian sauer wrote:
>>> Wed 02 Jan 2008 18:27, Rainer M Krug wrote:
>>>> you wrote in the a previous thread that one can use gdal 1.5
>>>> directly to access a WMS ressource which is defined in an xml file
>>>> (see snippet below).
>>>> As 1.5 is out (and I compiled with MrSid support - works nicely by
>>>> the way), I looked but could find no information on that feature.
>>>> Could you please elaborate how I can use this instead of setting up
>>>> a mapserver on localhost?
>>> my understanding was - feel free to correct me - dylan was refering to
>>> the OGR/GDAL vrt driver.
>>> http://www.gdal.org/gdal_vrttut.html
>>> http://www.gdal.org/ogr/drv_vrt.html
>> I would rather guess it was the "WMS -- Web Map Services" driver:
> Ah - now I understand. I still have to set up a WMS server, but I can
> access it through gdal instead of using r.in.wms.
Well, if you have the data directly accessible, I don't know if it is
the most efficient way to access it via a webserver and wms. The main
insterest of this is obviously to get data from a distant wms server...
Moritz
