[GRASS-user] Re: gdal 1.5 and WMS ressource --- PREVIOUSLY:How to best access hundreds of orthophotos -- mapserver as WMS server?
Dylan Beaudette dylan.beaudette at gmail.com
Thu Jan 3 16:06:58 EST 2008
On Wednesday 02 January 2008, Rainer M Krug wrote:
> Hi Dylan
> you wrote in the a previous thread that one can use gdal 1.5 directly to
> access a WMS ressource which is defined in an xml file (see snippet below).
> As 1.5 is out (and I compiled with MrSid support - works nicely by the
> way), I looked but could find no information on that feature. Could you
> please elaborate how I can use this instead of setting up a mapserver on
> localhost?
> Thanks a lot,
> Rainer
Hi Rainer,
Yes, the new GDAL format (as also mentioned by others) is documented here:
http://www.gdal.org/frmt_wms.html
My suggestion, as quoted below, did not include replacing a _mapserver_ (WMS
source)- rather support for WMS would allow r.in.gdal to replace r.in.wms...
or perhaps re-write r.in.wms as a wrapper to r.in.gdal by first creating the
XML config file. See http://www.gdal.org/frmt_wms.html for details.
Cheers,
Dylan
> Dylan Beaudette wrote:
> SNIP
>  > 7. once GDAL 1.5 is released it will be possible to an r.in.gdal and
> point it
>  > to an XML file defining a WMS resource. A mini-script might be able to
>  > construct the XML file on the fly...
>  > Unfortunately you will still have to manage the images that are
> imported into
>  > GRASS with GRASS commands, unless you constantly overwrite a
> temporary set of
>  > files  by always using the same names and the --o flag.
> SNIP
Dylan Beaudette
Soil Resource Laboratory
http://casoilresource.lawr.ucdavis.edu/
University of California at Davis
530.754.7341
