[GRASS-user] Re: r.watershed - forgot to mask out no data?
Daniel Victoria
daniel.victoria at gmail.com
Wed Jan 9 07:37:49 EST 2008
Investigating further I don't think the islands of the cost have much
to do with the problem. You can see in the attached jpg how the
streams generated do not go over one of the islands (top left of the
image - Fernando de Noronha, great SCUBA place)
Also, some streams are generated along the cost because the basin of
that region is extending into the ocean...
Any clues as to what is going on? Has anyone else seen this? I'm using
Grass 6.2.2 from the Debian repos
Cheers
Daniel
On Jan 9, 2008 10:12 AM, Daniel Victoria <daniel.victoria at gmail.com> wrote:
> I just noticed that there are some small islands of the coast of South
> America that are represented in the DEM that I though where not there.
> Could that mess up the basin delineation over the continent? Would
> that explain why the coastal basins shoot out to the ocean (Nodata
> region in the DEM)?
> Thanks
> Daniel
> On Jan 7, 2008 4:40 PM, Daniel Victoria <daniel.victoria at gmail.com> wrote:
> > Hi,
> > After a couple of days I got a successful output from r.watershed.
> > Well, almost successful. Some basins looks very weird, as you can see
> > in the attached file. Is it because I did not mask out the null cells
> > on the dem map (white area on dem30.jpg)?
> > Thanks
> > Daniel
Type: image/jpeg
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20080109/7d991300/streams_sa-0001.jpg
