[GRASS-user] About importing VMAP into GRASS... (as shapefiles)
sebastian sauer scb at lo-res.org
Fri Jan 11 05:02:04 EST 2008
Fri 11 Jan 2008 06:17, Hamish wrote:
> nikos.alexandris wrote:
> > I still didn't find a way to import coastlines from the
> > VMAP data base.
why not RTFM!? http://www.gdal.org/ogr/drv_ogdi.html
as usual frank warmerdam's doc is fantastic.
> > I tried to look after the:
> > mv: missing destination file operand after `.'
> > error message but I can't figure it out.
> there is a problem within the script.
ACK. i second that. also i never really found the script useful that's
why i never used it. :)
on a side note also don't expect VMAP0 data to be (overly) precise. YMMV,
though, depending on the area you are interested.
