[GRASS-user] About importing VMAP into GRASS... (as shapefiles)
Nikos Alexandris nikos.alexandris at felis.uni-freiburg.de
Fri Jan 11 08:29:25 EST 2008
Thank you guys...
I think I solved it now!
I found in GDAL mailing list following statement:
> It sounds like the case sensitive path issue that bit me a while back.
> A lot of vmap data was saved with mixed upper and lower case file
> names and
> file extentions.
> How I got around it is I placed the vmap0 data in a path without
> any upper
> case letters in it (/home/paul/tmp/vmap0) and ran ogrinfo and
> ogr2ogr from
> there.
by Paul Surgeon.
So, I just moved the v0eur folder out of my long
folder /home/nik/GeoData/World/VMAP which has a lot of dangerous Capital
letters ;-)
Now I get a decent output when I run:
$ ogrinfo gltp:/vrf/home/nik/v0eur/vmaplv0/eurnasia
'watrcrsl at hydro(*)_line'
Still didn't try to export anything but I think it will be easy since I
don't get any error messages from ogrinfo.
Than you all,
Nikos.
On Fri, 2008-01-11 at 11:02 +0100, sebastian sauer wrote:
> Fri 11 Jan 2008 06:17, Hamish wrote:
> > nikos.alexandris wrote:
> > > I still didn't find a way to import coastlines from the
> > > VMAP data base.
> why not RTFM!? http://www.gdal.org/ogr/drv_ogdi.html
> as usual frank warmerdam's doc is fantastic.
> > > I tried to look after the:
> > > mv: missing destination file operand after `.'
> > > error message but I can't figure it out.
> > there is a problem within the script.
> ACK. i second that. also i never really found the script useful that's
> why i never used it. :)
> on a side note also don't expect VMAP0 data to be (overly) precise. YMMV,
> though, depending on the area you are interested.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
Nikos Alexandris
Department of Remote Sensing & Landscape Information Systems
Faculty of Forestry & Environmental Sciences, Albert-Ludwigs-University Freiburg
Tel.  +49 (0) 761 203 3697 / Fax.  +49 (0) 761 203 3701 / Skype: Nikos.Alexandris
Address: Tennenbacher str. 4, D-79106 Freiburg i. Br., Germany
Name: not available
Desc: This is a digitally signed message part
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20080111/e7df4367/attachment.bin
