[GRASS-user] v.in.ogr fails on dbf with long column names
    Richard Greenwood
    richard.greenwood at gmail.com
    Fri Jan 11 08:04:05 EST 2008
On Jan 11, 2008 5:42 AM, Craig Leat <Craig at pid.co.za> wrote:
> Hi
> I have a shapefile and attributes in a dbf file. The dbf has two columns
> where the first ten characters of the column names are identical. The dbf
> driver appears to only consider the first ten letters of the name and so
> v.in.ogr fails reporting that two columns have the same name. Is there a way
> to only import selected columns? I could also delete a column before
> importing, but I am lacking some basic DBase know how so any pointers will
> be greatly appreciated.
> BTW the dbf is too big (94,000 rows) to load into OpenOffice Calc.
> Regards
> Craig
dbf field names are limited to 10 characters. ogr2ogr (part of GDAL)
has a -select clause which would allow you to select only specified
columns, but might not be able to distinguish between the identical
column names either.
Rich
Richard Greenwood
www.greenwoodmap.com
