[GRASS-user] problems with v.edit - merge
G. Allegri
giohappy at gmail.com
Fri Jan 11 19:40:02 EST 2008
I can't figure out how to solve a problem with a line feature shapefile I
have. It has been wrongly created as 81 single lines touching each other
with their vertexes. I need to merge the lines into a unique line. I've
tried with v.edit and the merge tool, two times. First time it gave me 32
lines, the second I receive the following result:
1 of 4 features selected from vector map <costa at PERMANENT>
Only 1 lines found, at least two needed
-1 lines merged
Building topology ...
Registering lines:
4 primitives registered
Building areas:
0 areas built
0 isles built
Attaching islands:
Attaching centroids:
Topology was built.
Number of nodes : 5
Number of primitives: 4
Number of points : 0
Number of lines : 4
Number of boundaries: 0
Number of centroids : 0
Number of areas : 0
Number of isles : 0
v.edit complete.
I can't understand what it means: it says it selected 4 lines but then just
1 line has been found. the post build report lists 4 lines... I'm a bit
confused.
I've manually merged all the categories too with v.digit, but nothing seems
to change (neither better nor worst!).
What am I doing wrong? What's the best method to achieve my task?
Thanks,
Giovanni
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20080112/b641e381/attachment-0001.html
