[GRASS-user] problems starting wxPython gui using wingrass
    nikos.alexandris at felis.uni-freiburg.de
    Thu Jan 17 12:50:20 EST 2008
Thanks a lot!
I will check this out later... or maybe tomorrow!
On Thu, 17 Jan 2008 18:49:05 +0100
 "Martin Landa" <landa.martin at gmail.com> wrote:
> Hi,
> related to wxpython
> make -C vdigit || echo
> /usr/local/src/grass_trunk/gui/wxpython/vdigit >> /usr/lo
> cal/src/grass_trunk/error.log
> make[1]: Entering directory
> `/usr/local/src/grass_trunk/gui/wxpython/vdigit'
> Makefile:27: warning: overriding commands for target
> `clean'
> ../../../include/Make/Rules.make:72: warning: ignoring
> old commands for target `
> clean'
> swig -c++ -python -shadow grass6_wxvdigit.i
> make[1]: swig: Command not found
> make[1]: *** [grass6_wxvdigit_wrap.cxx] Error 127
> make[1]: Leaving directory
> 1) swig is missing (just read the error output...)
> 2) please take a look also at README
> (gui/wxpython/README)
> 3) the code in gui/wxpython/vdigit is needed only for
> experimental
> digitization tool, the rest of GUI will work even if this
> fails...
> Martin
> 2008/1/17, nikos.alexandris at felis.uni-freiburg.de
> <nikos.alexandris at felis.uni-freiburg.de>:
> > wxgrass doesn't work.
> > Error's after "make" below.
> > Following modules are missing the 'description.html'
> file
> > in src code:
> > GRASS GIS compilation log
> > Started compilation: Thu Jan 17 16:20:58 CET 2008
> > Errors in:
> > /usr/local/src/grass_trunk/lib/ogsf
> > /usr/local/src/grass_trunk/visualization/nviz
> > On Thu, 17 Jan 2008 08:15:40 -0700
> >  Michael Barton <michael.barton at asu.edu> wrote:
> > > I'm glad that you're finally getting the correct
> code.
> > > I'm confused  about it's availability too. Please let
> us
> > > know how it runs once you  can get it and test it.
> > > Michael
> > > ____________________
> > > C. Michael Barton, Professor of Anthropology
> > > Director of Graduate Studies
> > > School of Human Evolution & Social Change
> > > Center for Social Dynamics & Complexity
> > > Arizona State University
> > > Phone: 480-965-6262
> > > Fax: 480-965-7671
> > > www: <www.public.asu.edu/~cmbarton>
> > > On Jan 17, 2008, at 4:54 AM,
> > > nikos.alexandris at felis.uni-freiburg.de  wrote:
> > > > Thank you for the clarification (again).
> > > > (1) ??? I can put my hand on fire (greek... or
> > > universal
> > > > expression) that I was getting an error with "svn
> up"
> > > but
> > > > now not!
> > > > (2) Yes... trunk... (sorry for insisting).
> > > > On Thu, 17 Jan 2008 10:28:41 +0100
> > > >> Hi,
> > > >> 2008/1/16, Nikos Alexandris
> > > >>> I am sorry for bothering again.
> > > >>> I am on ubuntu.
> > > >>> I updated (sudo svn up) from within
> > > >> general note, why are you running 'svn up' as
> sudo??
> > > >>> the /usr/local/src/MyGRASSsourceDirectory
> > > >>> Configured-compilled-installed.
> > > >>> No wxgrass anywhere.. only a few irrelevant
> scripts
> > > >> under... :
> > > >>> GRASS 6.3.0RC4
> (Peloponnese_HGRS87):/usr/local/grass-6.3.0RC4/etc/gui
> > > >>> ls
> > > >>> icons  scripts
> > > >>> So... I go in /usr/loca/src/MyGRASSsrcDir/gui
> > > >>> directory and I only find "wxpython" as a folder
> > > which
> > > >> does not contain
> > > >>> any "wxgrass" script.
> > > >>> GRASS 6.3.0RC4
(Peloponnese_HGRS87):/usr/local/src/release_20080109_grass_6_3_0RC4/
> > > > gui/wxpython
> > > >>> ls
> > > >>> archive  gm.wxp       grass-interface.dtd
>  mapdisp.py
> > > >>  scripts
> > > >>> gism.py  grassgui.py  Makefile
>             render.py
> > > >> Once more, in grass 6.3 is old wxpython code. Use
> > > >> svn-trunk instead.
> > > >> svn checkout
> https://svn.osgeo.org/grass/grass/trunk
> > > >> grass_trunk
> > > >> Martin
> > > >> Martin Landa <landa.martin at gmail.com> *
> > > >> http://gama.fsv.cvut.cz/~landa *
> >          Nikos Alexandris - Ph.D. Candidate
> >             Department of Remote Sensing
> >                        and
> >             Landscape Information Systems
> >                      (FeLIS)
> >       Faculty of Forestry and Natural Environment
> >           Albert-Ludwigs-University Freiburg
> >             Tel.  +49 (0) 761 203 3697
> >             Fax.  +49 (0) 761 203 3701
> >              Skype: Nikos.Alexandris
> >            Address: Tennenbacher str. 4
> >               D-79106 Freiburg i. Br.
> >                      Germany
                       and
                     (FeLIS)
                     Germany
