[GRASS-user] problems starting wxPython gui using wingrass
Martin Landa
landa.martin at gmail.com
Thu Jan 17 12:56:30 EST 2008
due to the problems, I disabled compiling vdigit by default for now.
It can be compiled manually, see README for detailed information.
http://trac.osgeo.org/grass/changeset/29739
Martin
2008/1/17, nikos.alexandris at felis.uni-freiburg.de
<nikos.alexandris at felis.uni-freiburg.de>:
> Thanks a lot!
> I will check this out later... or maybe tomorrow!
> On Thu, 17 Jan 2008 18:49:05 +0100
> "Martin Landa" <landa.martin at gmail.com> wrote:
> > Hi,
> > related to wxpython
> > make -C vdigit || echo
> > /usr/local/src/grass_trunk/gui/wxpython/vdigit >> /usr/lo
> > cal/src/grass_trunk/error.log
> > make[1]: Entering directory
> > `/usr/local/src/grass_trunk/gui/wxpython/vdigit'
> > Makefile:27: warning: overriding commands for target
> > `clean'
> > ../../../include/Make/Rules.make:72: warning: ignoring
> > old commands for target `
> > clean'
> > swig -c++ -python -shadow grass6_wxvdigit.i
> > make[1]: swig: Command not found
> > make[1]: *** [grass6_wxvdigit_wrap.cxx] Error 127
> > make[1]: Leaving directory
> > 1) swig is missing (just read the error output...)
> > 2) please take a look also at README
> > (gui/wxpython/README)
> > 3) the code in gui/wxpython/vdigit is needed only for
> > experimental
> > digitization tool, the rest of GUI will work even if this
> > fails...
> > Martin
> > > wxgrass doesn't work.
> > > Error's after "make" below.
> > > Following modules are missing the 'description.html'
> > file
> > > in src code:
> > > GRASS GIS compilation log
> > > Started compilation: Thu Jan 17 16:20:58 CET 2008
> > > Errors in:
> > > /usr/local/src/grass_trunk/lib/ogsf
> > > /usr/local/src/grass_trunk/visualization/nviz
> > > On Thu, 17 Jan 2008 08:15:40 -0700
> > > Michael Barton <michael.barton at asu.edu> wrote:
> > > > I'm glad that you're finally getting the correct
> > code.
> > > > I'm confused about it's availability too. Please let
> > us
> > > > know how it runs once you can get it and test it.
> > > > Michael
> > > > ____________________
> > > > C. Michael Barton, Professor of Anthropology
> > > > Director of Graduate Studies
> > > > School of Human Evolution & Social Change
> > > > Center for Social Dynamics & Complexity
> > > > Arizona State University
> > > > Phone: 480-965-6262
> > > > Fax: 480-965-7671
> > > > www: <www.public.asu.edu/~cmbarton>
> > > > On Jan 17, 2008, at 4:54 AM,
> > > > nikos.alexandris at felis.uni-freiburg.de wrote:
> > > > > Thank you for the clarification (again).
> > > > > (1) ??? I can put my hand on fire (greek... or
> > > > universal
> > > > > expression) that I was getting an error with "svn
> > up"
> > > > but
> > > > > now not!
> > > > > (2) Yes... trunk... (sorry for insisting).
> > > > > On Thu, 17 Jan 2008 10:28:41 +0100
> > > > >> Hi,
> > > > >> 2008/1/16, Nikos Alexandris
> > > > >>> I am sorry for bothering again.
> > > > >>> I am on ubuntu.
> > > > >>> I updated (sudo svn up) from within
> > > > >> general note, why are you running 'svn up' as
> > sudo??
> > > > >>> the /usr/local/src/MyGRASSsourceDirectory
> > > > >>> Configured-compilled-installed.
> > > > >>> No wxgrass anywhere.. only a few irrelevant
> > scripts
> > > > >> under... :
> > > > >>> GRASS 6.3.0RC4
> > (Peloponnese_HGRS87):/usr/local/grass-6.3.0RC4/etc/gui
> > > > >>> ls
> > > > >>> icons scripts
> > > > >>> So... I go in /usr/loca/src/MyGRASSsrcDir/gui
> > > > >>> directory and I only find "wxpython" as a folder
> > > > which
> > > > >> does not contain
> > > > >>> any "wxgrass" script.
> > > > >>> GRASS 6.3.0RC4
> (Peloponnese_HGRS87):/usr/local/src/release_20080109_grass_6_3_0RC4/
> > > > > gui/wxpython
> > > > >>> ls
> > > > >>> archive gm.wxp grass-interface.dtd
> > mapdisp.py
> > > > >> scripts
> > > > >>> gism.py grassgui.py Makefile
> > render.py
> > > > >> Once more, in grass 6.3 is old wxpython code. Use
> > > > >> svn-trunk instead.
> > > > >> svn checkout
> > https://svn.osgeo.org/grass/grass/trunk
> > > > >> grass_trunk
> > > > >> Martin
> > > > >> Martin Landa <landa.martin at gmail.com> *
> > > > >> http://gama.fsv.cvut.cz/~landa *
> > > Nikos Alexandris - Ph.D. Candidate
> > > Department of Remote Sensing
> > > and
> > > Landscape Information Systems
> > > (FeLIS)
> > > Faculty of Forestry and Natural Environment
> > > Albert-Ludwigs-University Freiburg
> > > Tel. +49 (0) 761 203 3697
> > > Fax. +49 (0) 761 203 3701
> > > Skype: Nikos.Alexandris
> > > Address: Tennenbacher str. 4
> > > D-79106 Freiburg i. Br.
> > > Germany
> and
> (FeLIS)
> Germany
Martin Landa <landa.martin at gmail.com> * http://gama.fsv.cvut.cz/~landa *
