[GRASS-user] problems starting wxPython gui using wingrass
Michael Barton michael.barton at asu.edu
Thu Jan 17 12:55:05 EST 2008
I have no idea about the others. But the wxPython errors are because
you need to install swig and configure --with-python in order to
create the new digitizing module. The rest of the gui looks like it's
OK.
Michael
______________________________
Michael Barton, Professor
Professor of Anthropology
Director of Graduate Studies
School of Human Diversity & Social Change
Center for Social Dynamics & Complexity
Arizona State University
Tempe, AZ  85287-2402
USA
voice: 480-965-6262; fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
On Jan 17, 2008, at 10:04 AM, nikos.alexandris at felis.uni-freiburg.de
wrote:
> FYI
> attached all (4) errors as a text file.
> On Thu, 17 Jan 2008 09:00:31 -0700
> Michael Barton <michael.barton at asu.edu> wrote:
>> Nikos,
>> You need to CD to each directory with a problem and type
>> make to see  what kind of errors you're getting. It looks
>> like you've got errors  in several modules.
>> Michael
>> C. Michael Barton, Professor of Anthropology
>> School of Human Evolution & Social Change
>> Phone: 480-965-6262
>> Fax: 480-965-7671
>> www: <www.public.asu.edu/~cmbarton>
>> On Jan 17, 2008, at 8:29 AM,
>> nikos.alexandris at felis.uni-freiburg.de  wrote:
>>> wxgrass doesn't work.
>>> Error's after "make" below.
>>> Following modules are missing the 'description.html'
>> file
>>> in src code:
>>> GRASS GIS compilation log
>>> Started compilation: Thu Jan 17 16:20:58 CET 2008
>>> Errors in:
>>> /usr/local/src/grass_trunk/lib/ogsf
>>> /usr/local/src/grass_trunk/gui/wxpython/vdigit
>>> /usr/local/src/grass_trunk/visualization/nviz
>>> On Thu, 17 Jan 2008 08:15:40 -0700
>>>> I'm glad that you're finally getting the correct code.
>>>> I'm confused  about it's availability too. Please let
>> us
>>>> know how it runs once you  can get it and test it.
>>>> Michael
>>>> Phone: 480-965-6262
>>>> Fax: 480-965-7671
>>>> On Jan 17, 2008, at 4:54 AM,
>>>>> Thank you for the clarification (again).
>>>>> (1) ??? I can put my hand on fire (greek... or
>>>> universal
>>>>> expression) that I was getting an error with "svn up"
>>>> but
>>>>> now not!
>>>>> (2) Yes... trunk... (sorry for insisting).
>>>>> On Thu, 17 Jan 2008 10:28:41 +0100
>>>>> "Martin Landa" <landa.martin at gmail.com> wrote:
>>>>>> Hi,
>>>>>> 2008/1/16, Nikos Alexandris
>>>>>> <nikos.alexandris at felis.uni-freiburg.de>:
>>>>>>> I am sorry for bothering again.
>>>>>>> I am on ubuntu.
>>>>>>> I updated (sudo svn up) from within
>>>>>> general note, why are you running 'svn up' as sudo??
>>>>>>> the /usr/local/src/MyGRASSsourceDirectory
>>>>>>> Configured-compilled-installed.
>>>>>>> No wxgrass anywhere.. only a few irrelevant scripts
>>>>>> under... :
>>>>>>> GRASS 6.3.0RC4
>> (Peloponnese_HGRS87):/usr/local/grass-6.3.0RC4/etc/gui
>>>>>>> ls
>>>>>>> icons  scripts
>>>>>>> So... I go in /usr/loca/src/MyGRASSsrcDir/gui
>>>>>>> directory and I only find "wxpython" as a folder
>>>> which
>>>>>> does not contain
>>>>>>> any "wxgrass" script.
>>>>>>> GRASS 6.3.0RC4
> (Peloponnese_HGRS87):/usr/local/src/release_20080109_grass_6_3_0RC4/
>>>>> gui/wxpython
>>>>>>> ls
>>>>>>> archive  gm.wxp       grass-interface.dtd
>> mapdisp.py
>>>>>> scripts
>>>>>>> gism.py  grassgui.py  Makefile
>>            render.py
>>>>>> Once more, in grass 6.3 is old wxpython code. Use
>>>>>> svn-trunk instead.
>>>>>> svn checkout https://svn.osgeo.org/grass/grass/trunk
>>>>>> grass_trunk
>>>>>> Martin
>>>>>> Martin Landa <landa.martin at gmail.com> *
>>>>>> http://gama.fsv.cvut.cz/~landa *
>>>         Nikos Alexandris - Ph.D. Candidate
>>>            Department of Remote Sensing
>>>                       and
>>>            Landscape Information Systems
>>>                     (FeLIS)
>>>      Faculty of Forestry and Natural Environment
>>>          Albert-Ludwigs-University Freiburg
>>>            Tel.  +49 (0) 761 203 3697
>>>            Fax.  +49 (0) 761 203 3701
>>>             Skype: Nikos.Alexandris
>>>           Address: Tennenbacher str. 4
>>>              D-79106 Freiburg i. Br.
>>>                     Germany
>                       and
>                     (FeLIS)
>                     Germany
> <grasstrunk_make_errors>
