[GRASS-user] problems starting wxPython gui using wingrass
nikos.alexandris at felis.uni-freiburg.de nikos.alexandris at felis.uni-freiburg.de
Thu Jan 17 12:04:16 EST 2008
FYI
attached all (4) errors as a text file.
On Thu, 17 Jan 2008 09:00:31 -0700
 Michael Barton <michael.barton at asu.edu> wrote:
> Nikos,
> You need to CD to each directory with a problem and type
> make to see  what kind of errors you're getting. It looks
> like you've got errors  in several modules.
> Michael
> ____________________
> C. Michael Barton, Professor of Anthropology
> Director of Graduate Studies
> School of Human Evolution & Social Change
> Center for Social Dynamics & Complexity
> Arizona State University
> Phone: 480-965-6262
> Fax: 480-965-7671
> www: <www.public.asu.edu/~cmbarton>
> On Jan 17, 2008, at 8:29 AM,
> nikos.alexandris at felis.uni-freiburg.de  wrote:
> > wxgrass doesn't work.
> > Error's after "make" below.
> > Following modules are missing the 'description.html'
> file
> > in src code:
> > GRASS GIS compilation log
> > Started compilation: Thu Jan 17 16:20:58 CET 2008
> > Errors in:
> > /usr/local/src/grass_trunk/lib/ogsf
> > /usr/local/src/grass_trunk/gui/wxpython/vdigit
> > /usr/local/src/grass_trunk/visualization/nviz
> > On Thu, 17 Jan 2008 08:15:40 -0700
> >> I'm glad that you're finally getting the correct code.
> >> I'm confused  about it's availability too. Please let
> us
> >> know how it runs once you  can get it and test it.
> >> Michael
> >> Phone: 480-965-6262
> >> Fax: 480-965-7671
> >> On Jan 17, 2008, at 4:54 AM,
> >>> Thank you for the clarification (again).
> >>> (1) ??? I can put my hand on fire (greek... or
> >> universal
> >>> expression) that I was getting an error with "svn up"
> >> but
> >>> now not!
> >>> (2) Yes... trunk... (sorry for insisting).
> >>> On Thu, 17 Jan 2008 10:28:41 +0100
> >>>  "Martin Landa" <landa.martin at gmail.com> wrote:
> >>>> Hi,
> >>>> 2008/1/16, Nikos Alexandris
> >>>> <nikos.alexandris at felis.uni-freiburg.de>:
> >>>>> I am sorry for bothering again.
> >>>>> I am on ubuntu.
> >>>>> I updated (sudo svn up) from within
> >>>> general note, why are you running 'svn up' as sudo??
> >>>>> the /usr/local/src/MyGRASSsourceDirectory
> >>>>> Configured-compilled-installed.
> >>>>> No wxgrass anywhere.. only a few irrelevant scripts
> >>>> under... :
> >>>>> GRASS 6.3.0RC4
> (Peloponnese_HGRS87):/usr/local/grass-6.3.0RC4/etc/gui
> >>>>> ls
> >>>>> icons  scripts
> >>>>> So... I go in /usr/loca/src/MyGRASSsrcDir/gui
> >>>>> directory and I only find "wxpython" as a folder
> >> which
> >>>> does not contain
> >>>>> any "wxgrass" script.
> >>>>> GRASS 6.3.0RC4
(Peloponnese_HGRS87):/usr/local/src/release_20080109_grass_6_3_0RC4/
> >>> gui/wxpython
> >>>>> ls
> >>>>> archive  gm.wxp       grass-interface.dtd
>  mapdisp.py
> >>>>  scripts
> >>>>> gism.py  grassgui.py  Makefile
>             render.py
> >>>> Once more, in grass 6.3 is old wxpython code. Use
> >>>> svn-trunk instead.
> >>>> svn checkout https://svn.osgeo.org/grass/grass/trunk
> >>>> grass_trunk
> >>>> Martin
> >>>> Martin Landa <landa.martin at gmail.com> *
> >>>> http://gama.fsv.cvut.cz/~landa *
> >          Nikos Alexandris - Ph.D. Candidate
> >             Department of Remote Sensing
> >                        and
> >             Landscape Information Systems
> >                      (FeLIS)
> >       Faculty of Forestry and Natural Environment
> >           Albert-Ludwigs-University Freiburg
> >             Tel.  +49 (0) 761 203 3697
> >             Fax.  +49 (0) 761 203 3701
> >              Skype: Nikos.Alexandris
> >            Address: Tennenbacher str. 4
> >               D-79106 Freiburg i. Br.
> >                      Germany
                       and
                     (FeLIS)
                     Germany
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20080117/69df0be0/grasstrunk_make_errors.obj
