[GRASS-user] problems starting wxPython gui using wingrass
Michael Barton
michael.barton at asu.edu
Thu Jan 17 11:00:31 EST 2008
Nikos,
You need to CD to each directory with a problem and type make to see
what kind of errors you're getting. It looks like you've got errors
in several modules.
Michael
____________________
C. Michael Barton, Professor of Anthropology
Director of Graduate Studies
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
Phone: 480-965-6262
Fax: 480-965-7671
www: <www.public.asu.edu/~cmbarton>
On Jan 17, 2008, at 8:29 AM, nikos.alexandris at felis.uni-freiburg.de
wrote:
> wxgrass doesn't work.
> Error's after "make" below.
> Following modules are missing the 'description.html' file
> in src code:
> GRASS GIS compilation log
> Started compilation: Thu Jan 17 16:20:58 CET 2008
> Errors in:
> /usr/local/src/grass_trunk/lib/ogsf
> /usr/local/src/grass_trunk/gui/wxpython/vdigit
> /usr/local/src/grass_trunk/visualization/nviz
> On Thu, 17 Jan 2008 08:15:40 -0700
> Michael Barton <michael.barton at asu.edu> wrote:
>> I'm glad that you're finally getting the correct code.
>> I'm confused about it's availability too. Please let us
>> know how it runs once you can get it and test it.
>> Michael
>> Phone: 480-965-6262
>> Fax: 480-965-7671
>> On Jan 17, 2008, at 4:54 AM,
>> nikos.alexandris at felis.uni-freiburg.de wrote:
>>> Thank you for the clarification (again).
>>> (1) ??? I can put my hand on fire (greek... or
>> universal
>>> expression) that I was getting an error with "svn up"
>> but
>>> now not!
>>> (2) Yes... trunk... (sorry for insisting).
>>> On Thu, 17 Jan 2008 10:28:41 +0100
>>> "Martin Landa" <landa.martin at gmail.com> wrote:
>>>> Hi,
>>>> 2008/1/16, Nikos Alexandris
>>>> <nikos.alexandris at felis.uni-freiburg.de>:
>>>>> I am sorry for bothering again.
>>>>> I am on ubuntu.
>>>>> I updated (sudo svn up) from within
>>>> general note, why are you running 'svn up' as sudo??
>>>>> the /usr/local/src/MyGRASSsourceDirectory
>>>>> Configured-compilled-installed.
>>>>> No wxgrass anywhere.. only a few irrelevant scripts
>>>> under... :
>>>>> GRASS 6.3.0RC4
>>>> (Peloponnese_HGRS87):/usr/local/grass-6.3.0RC4/etc/gui
>>>>> ls
>>>>> icons scripts
>>>>> So... I go in /usr/loca/src/MyGRASSsrcDir/gui
>>>>> directory and I only find "wxpython" as a folder
>> which
>>>> does not contain
>>>>> any "wxgrass" script.
>>>>> GRASS 6.3.0RC4
> (Peloponnese_HGRS87):/usr/local/src/release_20080109_grass_6_3_0RC4/
>>> gui/wxpython
>>>>> ls
>>>>> archive gm.wxp grass-interface.dtd mapdisp.py
>>>> scripts
>>>>> gism.py grassgui.py Makefile render.py
>>>> Once more, in grass 6.3 is old wxpython code. Use
>>>> svn-trunk instead.
>>>> svn checkout https://svn.osgeo.org/grass/grass/trunk
>>>> grass_trunk
>>>> Martin
>>>> Martin Landa <landa.martin at gmail.com> *
>>>> http://gama.fsv.cvut.cz/~landa *
> Nikos Alexandris - Ph.D. Candidate
> Department of Remote Sensing
> and
> Landscape Information Systems
> (FeLIS)
> Faculty of Forestry and Natural Environment
> Albert-Ludwigs-University Freiburg
> Tel. +49 (0) 761 203 3697
> Fax. +49 (0) 761 203 3701
> Skype: Nikos.Alexandris
> Address: Tennenbacher str. 4
> D-79106 Freiburg i. Br.
> Germany
