[GRASS-user] Vector drawings in PDF -> converting them
Kurt Heston
kheston at hestonsystems.com
Thu Jan 17 14:10:39 EST 2008
Dylan,
Will do. Is there a specific feature I should look for that solves my
specific problem?
--K
Dylan Beaudette wrote:
> On Wednesday 16 January 2008 11:22:02 pm Kurt Heston wrote:
>> I have a TON of vector drawings available to me in PDF format that I'm
>> georeferencing. So far, I'm doing it by converting them to PNGs and
>> using r.to.vect to massage them. This is really tedious and the data
>> isn't as clean as a straight vector conversion would be. In
>> Illustrator, I can see that all the vector math is there. That is, the
>> PDF isn't simply a wrapper around raster data.
>> I've tried opening the PDFs in Illustrator and exporting them as DXFs,
>> but Grass ignores a lot of the data when I do this...they look very
>> different in Grass once imported. I can export them as SVG from
>> Illustrator, but surprisingly, there doesn't appear to be a single
>> open-source tool available out there that converts SVG into some
>> mainstream GIS file format.
>> Does anyone have experience doing this type of conversion? Pointers
>> welcome.
> Check out Inkscape.
> Dylan
