[GRASS-user] Vector drawings in PDF -> converting them
Dylan Beaudette
dylan.beaudette at gmail.com
Thu Jan 17 15:39:05 EST 2008
On Thursday 17 January 2008 11:10:39 am Kurt Heston wrote:
> Dylan,
> Will do. Is there a specific feature I should look for that solves my
> specific problem?
> --K
Kurt-
Well, I would take a look at all of the vector (path) tools available in
Inkscape. I have not used to to work with much GIS data, but I do know that
it can import PDF data as vector (path) primitives.
Feel free to post your findings back to the list.
Cheers,
Dylan
> Dylan Beaudette wrote:
> > On Wednesday 16 January 2008 11:22:02 pm Kurt Heston wrote:
> >> I have a TON of vector drawings available to me in PDF format that I'm
> >> georeferencing. So far, I'm doing it by converting them to PNGs and
> >> using r.to.vect to massage them. This is really tedious and the data
> >> isn't as clean as a straight vector conversion would be. In
> >> Illustrator, I can see that all the vector math is there. That is, the
> >> PDF isn't simply a wrapper around raster data.
> >> I've tried opening the PDFs in Illustrator and exporting them as DXFs,
> >> but Grass ignores a lot of the data when I do this...they look very
> >> different in Grass once imported. I can export them as SVG from
> >> Illustrator, but surprisingly, there doesn't appear to be a single
> >> open-source tool available out there that converts SVG into some
> >> mainstream GIS file format.
> >> Does anyone have experience doing this type of conversion? Pointers
> >> welcome.
> >> _______________________________________________
> > Check out Inkscape.
> > Dylan
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
Dylan Beaudette
Soil Resource Laboratory
http://casoilresource.lawr.ucdavis.edu/
University of California at Davis
530.754.7341
