[GRASS-user] r.circle mult=4 does not work
Patton, Eric epatton at nrcan.gc.ca
Mon Jan 21 14:28:14 EST 2008
>The mult parameter only changes the z-values of each output pixel, not its position.
>If you create different output maps with varying mult parameters and query each one
>in turn, you'll see the size and extent of each output circle remain the same while
>their z-values vary according to each multiplier value.
>I'll add a hint in the manual page about it.
Updated in svn TRUNK.
~ Eric.
