[GRASS-user] Use of r.watershed
M S mseibel at gmail.com
Wed Jan 23 12:03:31 EST 2008
If you are in a relatively flat area, there needs to be consideration given
to the algorithm (to my knowledge there is no "choice" in the ArcGIS suite)
used to do the most important thing:  delineate the watershed basin.  Since
the question was asked about differences, this may apply if your terrain is
relatively flat.
>From the r.watershed manual, "If watershed divides contain flat to low
slope, *r.watershed* will generate better basin results than *r.terraflow*.
(*r.terraflow* uses the same type of algorithm as ESRI's ArcGIS watershed
software which fails under these conditions.)"
http://download.osgeo.org/grass/grass63/manuals/html63_user/r.watershed.html
Mark
On Jan 23, 2008 11:42 AM, <hydro at hydromodeling.com> wrote:
> Thanks.  I will try and change my threshold value this evening.
> A little background, I have completed this phase of the project at
> "work" using ArcHydro and it took about half a day total to run
> through the tools (fill, flow direction, flow accumulation, etc.).  I
> am trying to now do the same project at home using open source tools
> as a means of learning grass and as a comparison.  I wonder if the
> r.watershed algorithms differ enough from the ArcHydro ones to make
> execution times very different?  Any thoughts?
> Quoting Charles Ehlschlaeger <c.ehlschlaeger at insightbb.com>:
> > r.watershed will take a long time for a 8,600x10,300 cell DEM under any
> > circumstance. Your threshold value (400) might also be slowing things
> down.
> > How large should your smallest exterior watershed basin be? If your grid
> > cells are 10mx10m, your basins will be 400x10mx10m = 40,000 m^2: not
> that
> > large. The larger the th value, the faster the program will run.
> > Sincerely, chuck
> > Chuck Ehlschlaeger, Geospatial Science Consultant
> > PERTAN GROUP, http://pertan.com/
> > c.ehlschlaeger at insightbb.com, 309-255-2727
> > http://chuck.ehlschlaeger.info/
> > -----Original Message-----
> > From: grass-user-bounces at lists.osgeo.org
> > [mailto:grass-user-bounces at lists.osgeo.org] On Behalf Of
> > Sent: Wednesday, January 23, 2008 8:52 AM
> > To: Charles Ehlschlaeger
> > Cc: grass-user at lists.osgeo.org
> > Subject: RE: [GRASS-user] Use of r.watershed
> > Chuck,
> > Thanks for your reply.  The DEM has 8,627 rows and 10,270 columns.
> > The command line statement I used is:
> > r.watershed el=fill th=400 ac=fac ba=basins st=str
> > I have also tried using the -m and -4 flags placed after the r.watershed
> > part.
> > Thanks,
> > Matt
> >> How many rows and columns are in the input map? Also include the exact
> >> command line statement you use to run the program.
> >> Sincerely, chuck
> >> Sent: Wednesday, January 23, 2008 7:15 AM
> >> To: grass-user at lists.osgeo.org
> >> Subject: [GRASS-user] Use of r.watershed
> >> Hello All,
> >> I am new to GRASS but have been using GIS (mainly ESRI products) for
> >> quite a few years.  I am trying to learn how to use GRASS to carry out
> >> hydrology related analyses.  Currently, I am trying to use the
> >> r.watershed command to delineate the basins for a watershed.  My
> >> question is, how long would you expect it to take to run?  I am
> >> wondering if I am doing it wrong or if it just takes longer than I
> >> would expect.  The DEM is about 170MB TIFF before I import it to
> >> GRASS.  I have tried to run it a few times using different options,
> >> each time letting it run for 3 - 4 hours before killing it. I have
> >> tried both the -m and -4 flags.  Any input would be appreciated.
> >> _______________________________________________
> >> grass-user mailing list
> >> http://lists.osgeo.org/mailman/listinfo/grass-user
> >> No virus found in this incoming message.
> >> Checked by AVG Free Edition.
> >> Version: 7.5.516 / Virus Database: 269.19.9/1238 - Release Date:
> 1/22/2008
> >> 8:12 PM
> >> No virus found in this outgoing message.
> 1/22/2008
> >> 8:12 PM
> 1/22/2008
> > 8:12 PM
> 1/22/2008
> > 8:12 PM
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20080123/0994b615/attachment.html
