[GRASS-user] Inverse PCA in GRASS
Markus Neteler neteler at fbk.eu
Thu Jan 24 08:52:55 EST 2008
HamishB wrote:
> Michael Perdue wrote:
>> I think what your asking is if anyone knows how to apply the
>> transformation matrix that was used to derive you pca components in
>> reverse to get back to the original coordinate system. Something like
>> what is done in a decorrelation stretch?
>> Hopefully someone more knowledgeable than I can elaborate, but the
>> general idea is as follows;
>> if the i.pca is capable of divulging the eigenvectors, you can use
>> r.mapcalc to apply them in reverse. else;
>> r.covar -> m.eigensystem -> mapcalc -> "do something with your
>> principal components" -> mapcalc (inverse rotation) -> "original
>> coordinate system"
>> You can take a look at the bottom of the r.covar page for more info.
>> The big "if" is on the status of m.eigensystem. I tried the link to
>> the manual page and it is broken so I'm unsure of it's status.
> m.eigensystem has not been ported from GRASS 5 to GRASS 6.
> It is available from the GRASS 5 source code:
>   grass-5.4.0/src.contrib/CERL/misc/m.eigensystem/
> online:
> http://freegis.org/cgi-bin/viewcvs.cgi/grass/src.contrib/CERL/misc/m.eigensystem/
> While it is written in Fortan77 I see no reason why it couldn't be
> compiled with g77 or gfortran and run with modern versions of GRASS.
> The GRASS raster/imagery engines and file formats have not changed since
> GRASS 5 so there shouldn't be many problems.
> FWIW ./configure still checks for f2c.h
I have added m.eigensystem to GRASS Addons SVN with a slightly
updated Makefile. Grab here:
http://trac.osgeo.org/grass/browser/grass-addons/m.eigensystem
or from SVN
http://trac.osgeo.org/grass/wiki/DownloadSource
-> Subversion GRASS Addons source code repository
Markus
View this message in context: http://www.nabble.com/Inverse-PCA-in-GRASS-tp14195299p15060907.html
Sent from the Grass - Users mailing list archive at Nabble.com.
