[GRASS-user] v.coordinate.sh - improve this script?
Hamish hamish_b at yahoo.com
Thu Jan 24 19:52:48 EST 2008
Gabriele N. wrote:
> I made a script (attached) for the definition of interactive text
> file (containing the coordinates input and output) to be loaded
> later in v.transform.
> - Proceed doing a zoom (if necessary) on the first monitor (A map)
> and then identifying the input point (GCP) with one click.
be careful because d.zoom changes the region for the entire mapset.
probably better to use $WIND_OVERRIDE if you can.
> The script is certainly improved. For example viewing points included
> (example i.points,
the POINTS file created by i.points is a simple ascii file saved in the
$MAPSET/group/ dir. you can use standard unix command line tools to get
the coords to give d.graph for drawing.
Hamish
      ____________________________________________________________________________________
Be a better friend, newshound, and
know-it-all with Yahoo! Mobile.  Try it now.  http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
