[GRASS-user] center line with v.generalize ?
    Gabriele N.
    gis.gn at libero.it
    Thu Jan 24 09:10:27 EST 2008
Maris Nartiss-2 wrote:
> Just a quick idea - if vector map contains only rivers, You could try
> out v.to.rast and then r.thin till You get something similar to river
> and then convert back to vectors with r.to.vect.
> Report, if it works.
> Maris.
> 2008/1/24, Gabriele Nolè <gis.gn a libero.it>:
>> Ah, :-(
>> I do not think there is anything alternative.
>> I will be careful if you solve this problem.
>> However thanks
>> Gabriele
>> > On 24.01.2008 14:03, Gabriele N. wrote:
>> > > I would locate the midline of the river.
>> > >  So I would like to transform the polygon with the middle line.
>> > Ah now I get it. Unfortunately v.generalize doesn't support merging
>> > (yet). Also I don't have time to work on that at the moment. Daniel
>> > would you have time to implement this?
>> > --Wolf
>> > <:3 )---- Wolf Bergenheim ----( 8:>
>> grass-user mailing list
>> grass-user a lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
I have already tried with r.thin etc. .. but sometimes I need a little too
pixels (because the rivers is very narrow and contorted) to avoid errors of
approximation.
The problem is that choosing a region with high resolution happens ' out of
memory error '.
Thanks
View this message in context: http://www.nabble.com/center-line-with-v.generalize---tp15063073p15064642.html
Sent from the Grass - Users mailing list archive at Nabble.com.
