[GRASS-user] clip and rotate a raster
G. Allegri
giohappy at gmail.com
Thu Jan 24 18:53:15 EST 2008
I don't have a raster that fits my region. I should create a vector with
v.in.region, rasterize it and use it as a MASK... well, I hoped there was
something more linear. The same could be used to clip on the base of a
polygon.
The unsolved problem is rotation (and shift): making affine tranformations
using just a x-shift and y-shift parameter, and a rotation angle having set
a point as origin (or just around the "center" of the raster).
2008/1/25, Nikos Alexandris <nikos.alexandris at felis.uni-freiburg.de>:
> Hi,
> if you already have a raster that fits your region then simply create a
> MASK and just create a new raster with r.mapcalc.
> r.mapcalc clipped_rast=rast
> (r.mapcalc works only on the MASK so you can quickly clip any raster
> like that).
> On Fri, 2008-01-25 at 00:15 +0100, G. Allegri wrote:
> > Surely a stupid question, but I can't find a way to clip a raster on
> > the base of the region settings and/or the base of a vector. I can
> > MASK, I can reclass, but I can't clip!
> > Furthermore, is it possible to rotate a raster without the use of a
> > 1st polynomial rectification through GCPs?
> > Giovanni
> > grass-user mailing list
> > grass-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/grass-user
> Nikos Alexandris
> Department of Remote Sensing & Landscape Information Systems
> Faculty of Forestry & Environmental Sciences, Albert-Ludwigs-University
> Freiburg
> Tel. +49 (0) 761 203 3697 / Fax. +49 (0) 761 203 3701 / Skype:
> Nikos.Alexandris
> Address: Tennenbacher str. 4, D-79106 Freiburg i. Br., Germany
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20080125/7dde5082/attachment.html
