[GRASS-user] clip and rotate a raster
Nikos Alexandris
nikos.alexandris at felis.uni-freiburg.de
Thu Jan 24 19:04:05 EST 2008
Although I don't know how (!) I read in a post about i.rectify... Why
don't you dig-up the man page...
Cheers,
Nikos.
On Fri, 2008-01-25 at 00:53 +0100, G. Allegri wrote:
> I don't have a raster that fits my region. I should create a vector
> with v.in.region, rasterize it and use it as a MASK... well, I hoped
> there was something more linear. The same could be used to clip on the
> base of a polygon.
> The unsolved problem is rotation (and shift): making affine
> tranformations using just a x-shift and y-shift parameter, and a
> rotation angle having set a point as origin (or just around the
> "center" of the raster).
> 2008/1/25, Nikos Alexandris <nikos.alexandris at felis.uni-freiburg.de>:
> Hi,
> if you already have a raster that fits your region then simply
> create a
> MASK and just create a new raster with r.mapcalc.
> r.mapcalc clipped_rast=rast
> (r.mapcalc works only on the MASK so you can quickly clip any
> raster
> like that).
> On Fri, 2008-01-25 at 00:15 +0100, G. Allegri wrote:
> > Surely a stupid question, but I can't find a way to clip a
> raster on
> > the base of the region settings and/or the base of a vector.
> I can
> > MASK, I can reclass, but I can't clip!
> > Furthermore, is it possible to rotate a raster without the
> use of a
> > 1st polynomial rectification through GCPs?
> > Giovanni
> > grass-user mailing list
> > grass-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/grass-user
> Nikos Alexandris
> Department of Remote Sensing & Landscape Information Systems
> Faculty of Forestry & Environmental Sciences,
> Albert-Ludwigs-University Freiburg
> Tel. +49 (0) 761 203 3697 / Fax. +49 (0) 761 203 3701 /
> Skype: Nikos.Alexandris
> Address: Tennenbacher str. 4, D-79106 Freiburg i. Br., Germany
Nikos Alexandris
Faculty of Forestry & Environmental Sciences, Albert-Ludwigs-University Freiburg
Tel. +49 (0) 761 203 3697 / Fax. +49 (0) 761 203 3701 / Skype: Nikos.Alexandris
Name: not available
Desc: This is a digitally signed message part
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20080125/b9ff84c0/attachment.bin
