[GRASS-user] SHELL variable not set
Tue Jan 29 06:19:34 EST 2008
Martin Wegmann wrote:
> unfortunately I added 'rm .* ' instead of a 'rm $variable.*' in a GRASS
> script, hence I had to setup a new user account but when starting grass63 as
> the new user I get:
> sh-3.1$ grass63
> Cleaning up temporary files.....
> Starting GRASS ...
> GISDBASE='/data1/grassdb_africa';
> LOCATION_NAME='HI';
> MAPSET='nlm';
> ERROR: The SHELL variable is not set
> I never encountered it when installing Linux/GRASS for the first time, I
> searched a bit and found some GRASS shell scripts with this error message but
> I couldn't find a hint how to fix that.
> Is is a GRASS or Linux specific problem? Any idea which SHELL variable I have
> to set? And how to do so?
SHELL should be set from the last field in the user's /etc/passwd
entry[1] by any program which creates a session, e.g. login for
console logins, xdm/gdm/kdm for X sessions, sshd for ssh logins, etc.
[1] To be precise, the value of the pw_shell field in the "passwd",
structure returned by getpwnam() or getpwuid(). Some systems use e.g.
NIS or LDAP for storing user accounts instead of /etc/passwd.
The standard way for a user to change their shell is with the "chsh"
command.
