[GRASS-user] get message warning: unable to open font map in
i.points no such file (Solved)
Philipp Steigenberger
userlist at online.de
Wed Jan 30 08:17:29 EST 2008
I compiled the newest svn version (and also the 6.3.0RC4)
now all works well - no more problems with fonts
thank you
Philipp
Philipp Steigenberger schrieb
> Hi Hamish,
> thank you for helping always and everybody in the way you do! Approvals!!!
> d.legend or d.text don't print text. I get the same message:
> WARNING: unable to open font map '/usr/lib/grass/fonts/.hmp': No such
> file
> I'll ask the superuser for answering the questions of compiling.
> cheers
> om shantih
> Philipp
> Hamish schrieb:
>> Philipp Steigenberger wrote:
>>> I use in university a cvs of GRASS 6.3 in debian.
>>> The other day I got a problems with fonts in i.class and today the
>>> same using i.points.
>>> There are no words on the buttons. onlay grey beams (Balken)
>>> in Konsole I got the message
>>> file
>>> usr/lib/grass/fonts/.hmp contains:
>>> GRASS:~$ ls -A /usr/lib/grass/fonts/
>>> cyrilc.hmp greekc.hmp hersh.oc1 italicc.hmp romancs.hmp
>> scriptc.hmp
>>> gothgbt.hmp greekcs.hmp hersh.oc2 italiccs.hmp romand.hmp
>> scripts.hmp
>>> gothgrt.hmp greekp.hmp hersh.oc3 italict.hmp romans.hmp
>>> gothitt.hmp greeks.hmp hersh.oc4 romanc.hmp romant.hmp
>>> any idea what to change?
>>> May I (as a user) do something or do I need a superuser?
>>> Should we reinstall a newer cvs?
>> Apparently stroke fonts fail -- do things like d.legend or d.text print
>> text? 'unset GRASS_FONT' ?
>> self compilied? from original source or debian build?
>>> I there a mirror somewhere where we can find ready-to-use and
>>> up-to-date debian-packeges?
>> It is a moving target, so usually you'd build it yourself, e.g.
>> http://hamish.bowman.googlepages.com/debiangisfiles#compile
>> or get debian build rules from DebianGIS svn and run auto-build tools.
>> you might ask on the DebianGIS mailing list for better advice:
>> http://wiki.debian.org/DebianGis
>> GRASS 6.2.3 (in unstable now, soon to be in testing and etch-backports)
>> is fine for most work and is well tested.
>> Currently at backports.org for Debian/Etch is version 6.2.1
>> http://packages.debian.org/grass
>> Hamish
>> ____________________________________________________________________________________
>> Be a better friend, newshound, and
>> know-it-all with Yahoo! Mobile. Try it now. http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
-------------- nächster Teil --------------
Ein Dateianhang mit HTML-Daten wurde abgetrennt...
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20080130/1dda97e1/attachment.html
