[GRASS-user] get message warning: unable to open font map in
i.points such file
Philipp Steigenberger
userlist at online.de
Wed Jan 30 14:20:47 EST 2008
HI Paul,
the GRASS cvs I didn't compile by myself. It was installed into the
system. This days I couldn't run g.mkfontcap, cause I hadn't the permission.
Now that I have the superuser rights I already compiled GRASS svn -
without makeinstall;
I'll try the g.mkfontcap tomorrow with the cvs GRASS just to look if it
will work.
cheers
Philipp
Paul Kelly schrieb:
> On Sat, 26 Jan 2008, Philipp Steigenberger wrote:
>> Hi all,
>> I use in university a cvs of GRASS 6.3 in debian.
>> The other day I got a problems with fonts in i.class and today the same
>> using i.points.
>> There are no words on the buttons. onlay grey beams (Balken)
>> in Konsole I got the message
>> WARNING: unable to open font map '/usr/lib/grass/fonts/.hmp': No such
>> file
> Sorry, meant to reply to this earlier. The usual solution for this is
> to run:
> g.mkfontcap -o
> to re-generate the font file.
> Did you compile GRASS yourself? Were the compiled binaries moved to
> some other location in the filesystem without running "make install" -
> if so, the locations of the GRASS built-in fonts in the fontcap file
> would be wrong and it needs to be regenerated.
> Paul
-------------- nächster Teil --------------
Ein Dateianhang mit HTML-Daten wurde abgetrennt...
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20080130/ec8f0f67/attachment.html
