[GRASS-user] get message warning: unable to open font map in
i.points such file
Glynn Clements
glynn at gclements.plus.com
Thu Jan 31 04:15:51 EST 2008
Philipp Steigenberger wrote:
> the GRASS cvs I didn't compile by myself. It was installed into the
> system. This days I couldn't run g.mkfontcap, cause I hadn't the permission.
> Now that I have the superuser rights I already compiled GRASS svn -
> without makeinstall;
> I'll try the g.mkfontcap tomorrow with the cvs GRASS just to look if it
> will work.
If you don't have permission to modify etc/fontcap, you can use e.g.
"g.mkfontcap -s > ~/.gfontcap" to create a personal copy then use e.g.
"export GRASS_FONT_CAP=$HOME/.gfontcap" to make GRASS use that file
instead of the system copy.
