[GRASS-user] get message warning: unable to open font map in
i.points such file
Philipp Steigenberger
userlist at online.de
Thu Jan 31 05:24:17 EST 2008
Glynn Clements schrieb:
> Philipp Steigenberger wrote:
>> the GRASS cvs I didn't compile by myself. It was installed into the
>> system. This days I couldn't run g.mkfontcap, cause I hadn't the permission.
>> Now that I have the superuser rights I already compiled GRASS svn -
>> without makeinstall;
>> I'll try the g.mkfontcap tomorrow with the cvs GRASS just to look if it
>> will work.
> If you don't have permission to modify etc/fontcap, you can use e.g.
> "g.mkfontcap -s > ~/.gfontcap" to create a personal copy then use e.g.
> "export GRASS_FONT_CAP=$HOME/.gfontcap" to make GRASS use that file
> instead of the system copy.
Glynn,
In this way it works. But do I have to put this
into the .grass.bashrc, that don't have to export it every time I open a
new bash?
I opened a new bash and got there:
GRASS:~/gw$ echo $GRASS_FONT_CAP
GRASS:~/gw$
For my new GRASS svn it doesn't matter, but for me its in general
interesting to know how to work with /export/ in such cases. Is there a
file where the bash saves all the env-variables and how to influence it.
- But probably this is off-topic...
cheers
om shantih
Philipp
-------------- nächster Teil --------------
Ein Dateianhang mit HTML-Daten wurde abgetrennt...
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20080131/7697bb86/attachment.html
