[GRASS-user] Is mosaicing 24 bit images possible in Grass 6.2?
Fri Jul 4 13:25:16 EDT 2008
Moritz Lennert wrote:
> > You will lose information if you use r.composite,
> Just for my understanding: if you set levels to 256, you won't lose
> information, or ?
> It will just make displaying the result very slow.
Correct.
That assumes that the bands are limited to 256 levels. If you have
more than that, it is impossible to generate a composite image without
losing precision, as r.composite doesn't allow more than 256 levels.
There isn't really much point; the only reason for generating a
composite image is for display. For analysis, you are better off using
separate bands.
