[GRASS-user] Gdal-config with 6.4svn
G. Allegri giohappy at gmail.com
Sat Jul 5 10:23:33 EDT 2008
Have you solved the problem?
I'm facing it too...
I've uninstalled libgdal1-1.4.0 and libgdal1-1.4.0-grass, but it
doesn't solve it.
2008/7/2 doktoreas <thedoktor78 at gmail.com>:
> Markus Neteler OSGeo wrote:
>>> The system is an Ubuntu Hardy with Jachym's repository
>>> Gdal installed:
>>> libgdal1-1.4.0
>>> libgdal1-1.5.0
>>> libgdal1-dev
>> personally, I would not mix those versions. One version should
>> be enough.
> Yes, you are right. The 1.4.0 comes with qgis-grass-plugin from Tim
> Ubuntu repository. Hopes to see just one repository for Ubuntu (Osgeo?)  :)
> Thanks for all your suggestion.
> Bye
> Luca
> View this message in context: http://www.nabble.com/Gdal-config-with-6.4svn-tp18234142p18234719.html
> Sent from the Grass - Users mailing list archive at Nabble.com.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
