[GRASS-user] Gdal-config with 6.4svn
G. Allegri
giohappy at gmail.com
Sat Jul 5 14:23:08 EDT 2008
Solved...
I was looking for --with-gdal-includes when it was --with-includes
I need to rest :-)
2008/7/5 G. Allegri <giohappy at gmail.com>:
> Have you solved the problem?
> I'm facing it too...
> I've uninstalled libgdal1-1.4.0 and libgdal1-1.4.0-grass, but it
> doesn't solve it.
> 2008/7/2 doktoreas <thedoktor78 at gmail.com>:
>> Markus Neteler OSGeo wrote:
>>>> The system is an Ubuntu Hardy with Jachym's repository
>>>> Gdal installed:
>>>> libgdal1-1.4.0
>>>> libgdal1-1.5.0
>>>> libgdal1-dev
>>> personally, I would not mix those versions. One version should
>>> be enough.
>> Yes, you are right. The 1.4.0 comes with qgis-grass-plugin from Tim
>> Ubuntu repository. Hopes to see just one repository for Ubuntu (Osgeo?) :)
>> Thanks for all your suggestion.
>> Bye
>> Luca
>> View this message in context: http://www.nabble.com/Gdal-config-with-6.4svn-tp18234142p18234719.html
>> Sent from the Grass - Users mailing list archive at Nabble.com.
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
