[GRASS-user] Gdal-config with 6.4svn
Brian Bishop
brian at sopac.org
Sun Jul 6 18:37:47 EDT 2008
Still had this issue with:
--with-includes
Found workaround by changing the first line in gdal-config;
>From this:
CONFIG_LIBS="-L/usr/lib -lgdal1.5.0"
To this:
CONFIG_LIBS="-L/usr/lib -lgdal1.5.0 -I/usr/include/gdal"
Cheers
Brian
On Sat, 2008-07-05 at 20:23 +0200, G. Allegri wrote:
> Solved...
> I was looking for --with-gdal-includes when it was --with-includes
> I need to rest :-)
> 2008/7/5 G. Allegri <giohappy at gmail.com>:
> > Have you solved the problem?
> > I'm facing it too...
> > I've uninstalled libgdal1-1.4.0 and libgdal1-1.4.0-grass, but it
> > doesn't solve it.
> > 2008/7/2 doktoreas <thedoktor78 at gmail.com>:
> >> Markus Neteler OSGeo wrote:
> >>>> The system is an Ubuntu Hardy with Jachym's repository
> >>>> Gdal installed:
> >>>> libgdal1-1.4.0
> >>>> libgdal1-1.5.0
> >>>> libgdal1-dev
> >>> personally, I would not mix those versions. One version should
> >>> be enough.
> >> Yes, you are right. The 1.4.0 comes with qgis-grass-plugin from Tim
> >> Ubuntu repository. Hopes to see just one repository for Ubuntu (Osgeo?) :)
> >> Thanks for all your suggestion.
> >> Bye
> >> Luca
> >> View this message in context: http://www.nabble.com/Gdal-config-with-6.4svn-tp18234142p18234719.html
> >> Sent from the Grass - Users mailing list archive at Nabble.com.
> >> _______________________________________________
> >> grass-user mailing list
> >> grass-user at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/grass-user
Brian Bishop <brian at sopac.org>
SOPAC Secretariat
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20080707/e0019862/attachment.html
