[GRASS-user] Gdal-config with 6.4svn
maning sambale emmanuel.sambale at gmail.com
Sun Jul 6 23:41:47 EDT 2008
I just updated and compiled to day.  Seems to work now.
maning
On 7/7/08, Brian Bishop <brian at sopac.org> wrote:
> Still had this issue with:
> --with-includes
> Found workaround by changing the first line in gdal-config;
> >From this:
> CONFIG_LIBS="-L/usr/lib -lgdal1.5.0"
> To this:
> CONFIG_LIBS="-L/usr/lib -lgdal1.5.0 -I/usr/include/gdal"
> Cheers
> Brian
> On Sat, 2008-07-05 at 20:23 +0200, G. Allegri wrote:
>> Solved...
>> I was looking for --with-gdal-includes when it was --with-includes
>> I need to rest :-)
>> 2008/7/5 G. Allegri <giohappy at gmail.com>:
>> > Have you solved the problem?
>> > I'm facing it too...
>> > I've uninstalled libgdal1-1.4.0 and libgdal1-1.4.0-grass, but it
>> > doesn't solve it.
>> > 2008/7/2 doktoreas <thedoktor78 at gmail.com>:
>> >> Markus Neteler OSGeo wrote:
>> >>>> The system is an Ubuntu Hardy with Jachym's repository
>> >>>> Gdal installed:
>> >>>> libgdal1-1.4.0
>> >>>> libgdal1-1.5.0
>> >>>> libgdal1-dev
>> >>> personally, I would not mix those versions. One version should
>> >>> be enough.
>> >> Yes, you are right. The 1.4.0 comes with qgis-grass-plugin from Tim
>> >> Ubuntu repository. Hopes to see just one repository for Ubuntu (Osgeo?)
>> >> Thanks for all your suggestion.
>> >> Bye
>> >> Luca
>> >> View this message in context:
>> >> http://www.nabble.com/Gdal-config-with-6.4svn-tp18234142p18234719.html
>> >> Sent from the Grass - Users mailing list archive at Nabble.com.
>> >> _______________________________________________
>> >> grass-user mailing list
>> >> grass-user at lists.osgeo.org
>> >> http://lists.osgeo.org/mailman/listinfo/grass-user
> SOPAC Secretariat
| __.-._  |"Ohhh. Great warrior. Wars not make one great." -Yoda     |
| '-._"7' |"Freedom is still the most radical idea of all" -N.Branden|
|  /'.-c  |Linux registered user #402901, http://counter.li.org/     |
|  |  /T  |http://esambale.wikispaces.com|
| _)_/LI
